Using Labview control Agilent 33120A signals generated occurs an error occurs
hello,
The signal generator is the Agilent (33120A)
In Measurement & Automation which have caught this device (see below)
But VI execution to half Shique the following error window
in Initialize.vi, there is a problem
Such as photos
Seems to be unable to distinguish the devices?
How can i solve this problem? thanks~
Message 1 of 10
(6,061 Views)
Hi
Noticed that you are using serial port to communicate to instrument. Would you please double-check the serial setting parameters, such as Baud Rate, Flow Controls and etc. are insistent with the configuration on instrument? Or would you please try to use other interface rather than serial port.
If you have tried everything I mentioned above and it still raised that error, please manipulate the NI I/O Trace (You could find it in Windows Start menu) tool to trace and log the communication between PC and instrument. I should be helpful to analyze the root course if you investigate into that trace log. It would be great if you post it here!
- Charles
Message 2 of 10
(6,050 Views)
A query interrupted message comes from the machine itself so probably nthing is wrong with the communication but you started a second query before the first one was finished. So check for end characters more than baudrate.
greetings from the Netherlands
Message 3 of 10
(6,039 Views)
HI,
I check my baudrate is accurate(9600)
Message 4 of 10
(6,031 Views)
HI,
i check
serial port , Baud Rate(9600) , Flow control , parity   are all correct
However, I found a strange thing
I run this vi several times
Will not appear on the error message, and do not know why?  = =lll
Message 5 of 10
(6,030 Views)
try  another computer.
Message 6 of 10
(6,021 Views)
What about using NI I/O Trace to get the trace information?
Message 7 of 10
(6,000 Views)
Thanks all~
I have been solve this question,
I modify this vi , and then it can work.
Message 8 of 10
(5,979 Views)
Did you modify the end characters? I'm getting the exact same error.
Message 9 of 10
(5,583 Views)
Hi, trying to use a 33120A... exactly the same error.
Was there a resolution posted to this issue?
The tread ended but nobody posted the solution.
What was the change to teh VI?
catalin
Message 10 of 10
(5,303 Views)
