Using NI USB 6009, can i get all readings from a load cell measuring at 100Hz?
I would like to know whether a load cell, taking readings on a specimen which is fatigue loaded at 100Hz, can be connected to NI USB 6009 along with a computer to get the real time readings? The loading will continue upto 10-15minutes. The signals from the load cell has to be converted to force measurments  and has to be plotted later. Will a sampling rate of 1000 samples/sec be possible?
(3,486 Views)
Yes, absolutely. You can go up to 40000Hz for single channel. Use continuous mode, check the DAQ assistant to set it up.
Best,
Aniket
(3,470 Views)
