Using VB6 GPIB in Windows 7
I have an application that is in VB6 but running under Windows 7. Is there a different DLL I should be using in this case? Windows 7 won't let me register the original gpib-32.dll...
(6,212 Views)
Accepted by topic author tim8w1
You need a version compatible with windosw 7.
(6,190 Views)
Thanks. I had a copy of the old version in the folder with my project. Most of the calls started working fine after I removed the local copy. I was having problems with the Send command. Is this command no longer supported?
(6,167 Views)
The Send command is still listed in the help file. Can you use it in the NI-488.2 Interactive Control in MAX? do you get an error?
(6,164 Views)
Just had the address wrong. Workinig fine now...
(6,160 Views)
