Using VISA Write to input floating point number
I need to send a special command to a device using Visa Write (serial port). It's like "LIMIT 1.1".  "LIMIT" is ASCII string. There is no problem. But "1.1" needs to be a floating point number. If I just put  "LIMIT 1.1" in the command buffer, "1.1" will be ASCII string, not the floating point number which the device requies. How can I make this wok properly?       Thanks.
(4,657 Views)
Hi Ted
What instrument is this that that does not recognize 1.1 as a float.
maybe somebody has a driver for this instrument if you tell us the name and version of the instrument.
If you need this float in binary form (what I doubt) you could use a typecast from float to array of bytes.
But probably you need something like 1e1 instead of the decimal point, and even in a special number of characters.
Or the end of the string is not recognized
greetings from the Netherlands
(4,655 Views)
Hi Albert,
Thanks for the quick reply. Most of the commands for the device use ASCII charaters for numbers. Only the special command I mentioned a couple of other similar commands require numbers to be floating point numbers.
A more general question will be:  Is it possible to put different types of data in the Serial VISA WRITE buffer (because the command for VISA WRITE appears to be string only although it can be diplayed differently).
I am not very familiar with Labview. You mentioned typecast from float to array of bytes. How can I put that as a string for Visa write command?
Thanks again.
(4,643 Views)
Hi
I made you an example of how to convert a single into a four byte array and then into a four byte string. that is accepted by visa
(4,636 Views)
Thank you very much.
I will try it tomorrow.
(4,628 Views)
The ascii representation of a floating point number is a floating point number.
what representation other than that do you need?
single,double,extended?
and what endian type?
(4,145 Views)
