VB .NET reports "Length cannot be less than zero"
... when calling Device.ReadString()
(3,683 Views)
Have you tried running the shipping example that installs with the VISA support called SimpleReadWrite. It should be installed on your computer at
C:\Program Files\National Instruments\MeasurementStudio70\DotNET\Examples\Visa\SimpleReadWrite.
I just ran it and it works fine. Even if you try to perform a ReadString() with nothing attached it should just return a time out error.
JoshuaP
(3,683 Views)
I discovered the problem. I was reading the results from ReadString() into a string buffer. The values being returned by the device were binary, and there was a binary 0 within the string, which caused everyting to blow up. The problem is that the .NET framework handles strings differently than it did in VB6, where a binary 0 within a string wasn't a problem. I changed to reading the results of ReadString() into a byte array and everything works fine now. I guess .NET reads a binary 0 literally (nul), which wreaks havoc.
Lesson learned. Another step up the .NET learning curve.
(3,683 Views)
