VB6, W2K, always crashes 2nd time run in VB design mode.
In VB6 design mode, start up app which performs a SendIFC, then ibdev's and ibonl's the devices connect to the GPIB interface. Exit app which takes all devices off line (ibonl). If start app again the SendIFC crashes Win 2000 and automatically reboots PC. The VB created executable works fine.
This sounds very similar to the David Montigny of 4/4/2000.
(4,366 Views)
Pablo,
Having EXACT same problem, NI claims it is a WINDOWS/microsoft problem.
I tried several configurations ( vb5/win98se, vb6/win98se ) but it
only happens with vb6(sp4)/win2000.
My program:
Private Sub Form_Load()
Dim GPIB_BD As Integer
ibfind "GPIB0", GPIB_BD
End
End Su
This will be interesting, talking to microsoft. They probably don't
know what GPIB is, but we are in the middle, h
aving this problem.
Keep me informed.
TooN
(4,366 Views)
This sounds very familiar. Could you attach a sample project with minimal code that reproduces this problem?
(4,366 Views)
My (Antoon) program:
End
End Sub
Tried with VB6/WIN2000/NI-GPIB 1.60 and VB6/WIN2000/NI-GPIB 1.70, both
crashed.
Seems to happen ONLY with VB6/WIN2000, VB5 no problem, also VB6/WIN98 no
problem.
Antoon
(4,366 Views)
It may be that you're swapping the parameter of the ibonl call. It's typically ibonl(ud,0) to bring an instrument offline.
(4,366 Views)
Remember, if you don't use an ibonl(ud,0) for all ud's at the end of your program, it is likely to give the BAD_POOL_CALLER blue screen in Windows 2000.
(4,366 Views)
