VI_GPIB_REN_DEASSERT_GTL in C# .NET
Hi Guys,
Can anyone help me too understand how I would implement "VI_GPIB_REN_DEASSERT_GTL" interface command in C#? without having too wrap VISA32.DLL to extract viGpibControlREN().
Many thanks
Nigel
(4,858 Views)
Hi Nigel,
It is a bit unclear whether or not you have implemented general functionality of visa in c# yet. You do this by adding the namespace:
using NationalInstruments.VisaNS;
After which you should be able to call all the visa functions directly. The viGpibControlREN function should be available passing the session and mode in as it is in other environments.
Otherwise, if it is a problem with this particular function, please do reply again.
References: C# and Visual Basic .Net Instrument Control Tutorial
Regards
Ian S
Applications Engineer CLA
National Instruments UK&Ireland
(4,839 Views)
Thanks Ian,
I have implemented in C#. I was using a MessageBasedSession which does not expose controller methods. I changed to a GpibSession which did expose  the
ControlRen() method and also ReaddressingEnabled() that I later foundI needed.
I have done a lot of VBA VISA stuff in the past and thought mapping over to C# would be pretty streight forward but therre are some gotchas.
Thanks for the reply
Nigel
(4,837 Views)
Hi Nigel,
Makes sense, I hadn't picked up that you were using a message based session. All the best with your programming.
Ian S
(4,835 Views)
