VIA 5630 error 0xBFFA4004
Hi
We used a VNA PXIe 5630 and when try to execute the calibration  with automatic module ), some time we have the error 0xBFFA4004 .
the error occured at function :
        public int PerformCalibrationAction(string portList, NivnaCalibrationAction actionType)
            int pInvokeResult = PInvoke.PerformCalibrationAction(Handle, portList, actionType);
            TestForError(pInvokeResult);
            return pInvokeResult;
any idea for this error
(4,265 Views)
Hi Omar59,
Can you be more specific about the devices you are using ?
Following this post, it seems like a trigger issue, like thebatmanboy said.
Regards.
(4,234 Views)
I use the VNA PXIe-5630 with the automatic calibration module ( Part number 154748A-01).
(4,226 Views)
I have also an error ( I think it 's the same probleme ), on the NI-VNA SFP software.
I attached a picture
(4,222 Views)
