VISA ERROR 0xBFFF0030 (-1073807312)
Hi, I am stucked with a problem with communication between Labview and Keysight U2542A. I need to do single-shot measurements, but after a few measurements the hole thing drops down. After that I have to restart the program and the device too.
Here is the error messege:
! VI_ERROR_ABORT: Operation was aborted
Visa ErrorCode: 0xBFFF0030 (-1073807312)
! Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
I am desperated cause I do not know how to fix it.
Thank you for any help.
(1,573 Views)
Please add your vi. Including the frontpanel settings.
You programmed something wrong.
greetings from the Netherlands
(1,547 Views)
Hard to debug without code...
(1,546 Views)
