VISA ERROR 1 at Property Node (arg 1) in VISA Configure Serial Port
Hi all,
I have build an exe that connect with RS232. It works fine on my computer which is Windows XP but got an error when I try on Windows 7. I've already install NI Visa Runtime but still didn't work. I'm using Labview 2012 for the development.
 Thank You.
(3,155 Views)
My wild guess is you are trying to use a serial port that does not exist on your deployment computer.
(3,146 Views)
Well I've checked that part too. All the serial port settings are correct.
(3,119 Views)
