VISA Enable Event : Error -1073807339
Whenever device driver tries to execute "VISA Enable Event" function with event type "Service Request" It gives an error "Error -1073807339 occurred at VISA Enable Event in Agilent 3352X Series.lvlib"
I am successfully executing *IDN?\n command and reset command using VISA.
Best Regards
Sumit Memane
CLAD, CTD
(3,731 Views)
Hi sumit04,
I have exactly the same Problem. Have you already found a solution for it?
Regards
(3,234 Views)
HI,
I didn't get any solution for the same problem, but I have a work-around to avoid that problem.
The Reset.vi causing an issue so disabled it for now
Best Regards
Sumit Memane
CLAD, CTD
(3,211 Views)
finally I solved the problem for me. I had to adjust the Windows firewall settings. The Enable Event Message uses additional resources than the other messages.
Regards
(3,194 Views)
Can you post some screenshot what exactly you changed in Firewall
Best Regards
Sumit Memane
CLAD, CTD
(3,188 Views)
There's a NI-page for this topic: https://www.ni.com/de-de/support/documentation/supplemental/10/configuring-software-and-hardware-fir...
I think for our problem it's important to allow access  for the NIvisaic
In fact I opened the firewall for all NI applications and for those needed for VISA (searched for VISA in the firewall settings).
So I can't say which setting it was exactly that leaded to success.
(3,185 Views)
In my driver package there is an "Initialize_LAN.vi" and a "Reset_LAN.vi".
There is a bug in the "Initialize_LAN.vi", the "Reset.vi" in ​​the Reset (Enable) case has to be replaced by the "Reset_LAN.vi".
Apparently the problem was already recognized by the creator of the driver, but these vi's are not displayed in the function palette.
(2,403 Views)
