VISA GPIB problem after switchig from NT-> W2000
application was written in LV 5.0.1 and run under NT for several years without problem. After installation of Win2000 the VI's communicating with instrr (GPIB) via VISA are not working.
(3,477 Views)
witch gpib board do you use and witch version of drivers did you install on
w2k?
"marekf" schrieb im Newsbeitrag
news:506500000008000000C6BF0000-1075935269000@exchange.ni.com...
(3,477 Views)
card GPIB-PCMCIA
driver NI488 2.1
(3,477 Views)
Hello marekf,
Thank you for contacting National Instruments.
If you are using an older version if NI-VISA, the NI-VISA library
(visa32.dll) will fail to load when guests and non-administrators are
logged onto Windows 2000. Guests and non-administrators do not have
read/write access to the registry key that VISA is trying to access.
The symptom may be a warning dialog box from the OS or an error, (such
as -1073807360), in viOpenDefaultRM.
To avoid this problem, upgrade to the latest version of VISA or follow
the procedure below:
1. Log onto the computer as the administrator and open
the registry editor (regedt32.exe).
2. Explicitly grant the guest account write access
under HKEY_LOCAL_MACHINE\Software\National
Instruments\NI-VISA for Windows 9
5/NT. Choose
the Security>>Permissions menu item.
If "Everyone" is present, double-click it and
modify the permissions to "Full Control". If not,
click "Add", choose "Everyone", and give
them "Full Control".
The latest version of VISA can be obtained using the following link:
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C0E91?opendocument&node=132060_US
I hope this helps! If this does not solve your problem, let me know.
Matthew C
(3,477 Views)
