VISA HEX 0x BFFF0000 Error code
Hai Everyone
I feel difficulty in fixing the particular error in serial communication explained below.
I am using NI PXI-6221 for Digital I/O and Analog I/O. Along with this i am using serial ports for communication with two embedded based systems.
At starting i can able to configure the serial ports and able to establish communication between PXI and the another hardware. After a certain periodof time,i am getting the error code attached below.
If i do the same process in Laptop its working fine without DAQ operations. While using the same PXI without doing any operations through DAQ, the serial communication working properly but not 100%.
If i get some support from you, I can try to solve this error.
Thanks and Regards,
Sakthimurugan
Message 1 of 1
(4,671 Views)
