VISA, MAX, USB-RAW Session, Reading device descriptor
I have to read the bcdDevice value contained in the device descriptor from an USB device. I tried to read the data via the MAX Interactive Control Panel using the 'viUsbControlIn' Tab with the parameters: bmRequestType = 0x80, bRequest = 6 (get descriptor), wValue = 0x0100 (device descriptor), wIndex = 0, wLength = 18. Doing so the Computer crashes (It gets a RESET !!!!). Trying to read viewer data (14 bytes) MAX doesn't respond any more. I am using NI-VISA3.5 , MAX 4.0.2.3002. Now is there any idea how to read the bcdDevice value a different way ?
Regards
(3,749 Views)
perhaps the following two links give a solution for your problem:
USB RAW Control Communication in LabVIEW
Beyond Logic
To get more information about the reason for the crash, set the following changes in Settings - Control Panel - System - Advanced
ThSa
Message Edited by ThSa on 04-24-2006 04:10 PM
(3,703 Views)
