VISA: Parallel threads and locking instruments
i have 50 instruments that are controlled in two threads running at the same time.
Thread 1: Only VISA write (configuration of the instruments)
Thread 2: Visa write and Visa read (read measurement from instrument)
Can i now simply add the "Visa Lock Async VI" before the write and "Visa Unlock" at the end?
Thread 1: Visa Lock -> Write -> Visa Unlock
Thread 2: Visa Lock -> Write -> Read -> Visa Unlock
(5,464 Views)
It is really best if you can put all of the instrument control into a single thread.  That way you don't have to play these lock-do something-unlock games.  A Queued Message Handler works wonderfully for this situation.  But if you insist on not doing that (I know there are situations where you can't), then a Semaphore is really the way to go.
(5,454 Views)
Thanks for the help.
But it is also working with the Visa lock/unlock?
Using sempahores makes it very unreadable as i have to create new input/outputs to all VIs for the semaphores.
And the Visa addresses are already available for lock/unlock.
(5,452 Views)
Hello OnlyOne,
yes this should work.
What you can also try is to set read and write to synchronous mode
Choosing between Synchronous and Asynchronous VISA Functions
Hope this helps a little bit.
best regards
Alexander
(5,431 Views)
