VISA RAW FOR USB USING PIC18F4550
Try putting a delay (a sequence structure with a wait in it)  between your VISA Write and your VISA Read, it might help the problem.
Message 11 of 18
(3,690 Views)
Thank for suggestion but it does not working. The delay was the first stuff that I have tried. 🙂
Message 12 of 18
(3,686 Views)
Hello Bart,
Have you found a solution for your problem? I have the same problem, I can write to the uC but I can't read from the uC.
Have a nice day
Ronald
Message 13 of 18
(3,576 Views)
Found the problem.
The descriptor file (USBdsc.c) of MikroC Pro was not correct.... A few changes and it works....
Regards.
Ronald
Message 14 of 18
(3,570 Views)
Hello Rtessel,
Nop, I do not have any answer but if it works for you, could you please give me your solution?
Thanks.
Bart
Message 15 of 18
(3,564 Views)
Hello Bart,
The generated descripter file "USBdsc.c" by mikroC Pro for PIC v.5.6.0 I changed a part of the "configuration 1 descriptor":
 it was like this:
 // Endpoint Descriptor
     0x07,
     0x05,
     USB_HID_EP | 0x80,
     USB_TRANSFER_TYPE,
     0x40,0x00,
     EP_IN_INTERVAL,
     0x07,
     0x05,
     USB_HID_EP,
     USB_TRANSFER_TYPE,
     0x40,0x00,
     EP_OUT_INTERVAL
Changed into:
   0x07,
   0x05,
   USB_HID_EP,
   2,
   0x40,0x00,
   EP_IN_INTERVAL,
    0x07,
    0x05,
    USB_HID_EP | 0x80,
    2,
    0x40,0x00,
    EP_OUT_INTERVAL
 Ronald
Message 16 of 18
(3,557 Views)
Thanks! I'll try this ASAP.
Compliments!
B@rt
Message 17 of 18
(3,540 Views)
Dear all,
is this solution still valid? I am having the same problem - I am able to send data to microcontroller through VISA write, but when I try to read I get the error  (Hex 0xBFFF003A) .
is the problem in the firmware of the microcontroller? I am not the one who wrote the firmware so I cannot modify it and I am not experienced in coding....
Message 18 of 18
(2,433 Views)
