VISA + Serial Communication -help Help Needed !!!!
i have sensor temperature i can read the temperature with my ni mydaq no problem with that but in need to send this temperature to anther user with uartft232 any idea how i can do it
(3,474 Views)
Hey,
One question. Do you have the NI-Serial driver already installed? This will be necessary for achieving serial communication. With this driver's functions you will be able to write and read data using serial communication.image.png
You can download NI-Serial in the foll
(3,439 Views)
The NI Serial driver is only necessary if you are using a serial port from an NI device.  But VISA is the right API for communicating over a serial port.
(3,416 Views)
yes i install every thing
(3,408 Views)
Maybe this example program will give you insight on how to do serial communication with your device. You can find more related examples in LabVIEW ---> Help ---> Find Examples.
(3,399 Views)
