VISA USB control in
How to confirm the index,value,request type,request of the the USB control in fouction.And please give me some advice about the control pipe.
(5,137 Views)
Paper accepts any kind of writing.  Asking about how to use paper won't help you to learn a new language.
USB is a protocol.  How it is used exactly depends on the language your device supports (command set).  Each device is different.
Everything else (standard USB commands) are listed in Chapter 9 of the USB specification on the website www.usb.org under http://www.usb.org/developers/docs/
(5,109 Views)
Hi, How or where can I get the Request,Request type,value and index from my device? How can I make use of the control pipe?
(5,099 Views)
please read the answer you already got
greetings from the Netherlands
(5,094 Views)
