VISA Write and termination
I am using a modified version of the Basic Serial Write and Read VI from
National Instruments\LabVIEW 7.1\examples\instr\smplserl.llb
and I have been attempting to write a command and receive a response using RTS/CTS flow control. Every time the program reaches the VISA Write VI, it waits until the timeout and returns no data. Could this be a termination error? Should I use Wait On Event and associated VIs in place or possibly in conjunction with flow control? The error received is just a general “operation was not completed before timeout was reached” kind of error. Any general notes on writing a string command would be much appreciated.
(3,176 Views)
You're getting a timeout error on the VISA Write? If that's the case, the instrument might not be actually set up for handshaking or maybe there's a problem with the cable. Have you tried using Hyperterminal to communicate? If you get a timeout error on VISA Read, then there's a lot of possibilities. You perhaps are not sending a termination character with your write and the instrument doesn't receive a valid command to send data. Or the comm parameters are incorrect. Or the cable is bad. Or you've set VISA Read to expect a termination character and the instrument doesn't send one. In any case, I always recomend trying communication in Hyperterminal or something similar before writing any LabVIEW code. Getting serial communication to work is hard enough without having to throw in new code.
(3,162 Views)
