VISA doesn't find my USBTMC
I have a USBTMC device. When I try to connect  the USBTMC device, It give me an error message.
return value : BFFF003E
status name : VI_ERROR_IO
 I can see the USB Device in MAX , but  it's show "Unknown".
The USB driver is NIUSBTMC.SYS .
I have checked the interface Descriptor. Could you help me solve the problem?
(3,484 Views)
What USB instrument are you using? And is it truely USBTMC compliant?
(3,475 Views)
Also make sure you are using NI-VISA. If you have installed any other VISA on your system like Agilent VISA it will not work. You will need to uninstall the other 3rd party VISA.
-Josh
(3,462 Views)
