VISA error 0xBFFF0072 while communicating with Thornton 770MAX
I am running LabView to interface with two devices at the same time- a IOTech PersonalDaq/56 (over USB) and a Thornton 770Max via RS232. The program I created works fine for the Daq, but I am having issues with the RS232 communication.
When I go into the Instrument I/O Assistant and validate my setting everything seems to work well and the data is properly placed into tokens. As soon as I run my full program the first time no data is displayed on the front panel (I wired the I/O Assistant directly to a string output, all inside of a "While Loop" for data acquisition being active). After I stop the program all NI applications stop interfacing with the Thornton and when I go to validate the settings in the I/O Assistant again I get error oxBFFF0072.
There are no other running programs that would be interfacing with the Thornton. I have also tried doing a full VISA setup as the session in, and then closing it from the session out of the I/O Assistant, and keep getting the same error.
Any help is greatly appreciated.
(3,796 Views)
Based on your error, it sounds like the serial device is in use. Make sure to restart your computer and open NI MAX, and try to run a test panel. You can follow this guide to make sure that your serial device is set up properly: http://www.ni.com/gettingstarted/setuphardware/instrumentcontrol/serialconnect.htm
Trevor B.
PSE
(3,765 Views)
