VISA error -103807300/ LabVIEW 8.2
  When I run the VI on Real Time and My Computer, the VI can run, but when I put the VI on FPGA, that is to run the VI on FPGA target, it
gives error -1073807300, and the VI cannot run, I just use the VI from the standard example, the VI code has no problems, it has finished
compile but cannot download the VI to the FPGA.
  At the same time, it seems that the FPGA is not connected as I cannot add other I/O slots from the FPGA target, I use cRIO-9104.
  The error is the following:
   X Target Specific Error Encountered
   A driver for the target returned the following error. Consult the LabVIEW help database or the target documentation for help in resolving the issue.
  Error Code: -1073807300
  VISA: (Hex 0xBFFF003C) insufficient system resources to perform necessary memory allocation.
May you give me some help?
Thank you!
Maxwell
(4,656 Views)
Duplicate post.
Posting the same question twice a little while later won't get you an answer any more quickly. If fact, it might annoy some into not helping you.
(4,621 Views)
Hi Maxwell,
You said you are using a standard example; what example are you using? Have you edited the examples code at all? If you are using a shipping example, then did you following the linked directions for moving the example to your FPGA target?
Moving Examples to Another FPGA Target
http://zone.ni.com/devzone/cda/tut/p/id/5075
I hope this helps!
Nick R
NI
(4,593 Views)
