VISA error = timeout expired before operation completed
  Hi
  I have been developing a simple C# WindowsForm program by VS2010 for Agilent E3634A Power Supply.
  I try to initialize driver here in Main function. I just get instance of the object and initialize the driver. With the button click, I want to open output and then read voltage. It gives me always "VISA error  = timeout expired before operation completed" error.
 I think I have to open a session and set all serial parameters same as instrument but I do not know how to open session by IVI COM. Any help? Thanks
  using Ivi.Driver.Interop;
  using Agilent.AgilentE36xx.Interop;
  string resourceDesc = "ASRL5::INSTR";      //RS232 COM=5
          public MainForm()
            InitializeComponent();
            try
                driver = new AgilentE36xx();
                driver.Initialize(resourceDesc, idquery, reset, "DriverSetup= Model=E3634A,Trace=false");
            catch (Exception e)
                MessageBox.Show(e.Message);
         private void button3_Click(object sender, EventArgs e)
            driver.Outputs.Enabled = true;
             // Get Output1 object.  get_Name(1) returns "Output1".
            IAgilentE36xxOutput pOutput1 = driver.Outputs.get_Item(driver.Outputs.get_Name(1));
             // Measure the output voltage
            measuredvolt = pOutput1.Measure(AgilentE36xxMeasurementTypeEnum.AgilentE36xxMeasurementVoltage);
(4,939 Views)
