VISA ethernet control on LabVIEW Runtime 8.2 question
Software & Hardware:
LabVIEW 8.2
WinXP Pro SP2
Rhode & Schwarz FSQ Signal Analyzer
I have developed a VI to control a Rhode & Schwarz FSQ Signal Analyzer via TCP/IP. I ran into a problem when I tried to build an executable of that VI to run on another computer that only has LabVIEW runtime. It seems that my program relies on the Measurement & Automation Explorer to initialize communications with the instrument. The executable version cannot communicate with the FSQ when it is run on a computer that does not have MAX installed. Is there a way to use my program on a computer that does not have the LabVIEW development suite installed?
Ricardo
(3,743 Views)
If you want to use VISA, you have to install it. When you create the installer, you have the option to include the VISA run-time and the VISA configuration support. You could also include MAX if you needed to ever change the settings.
(3,738 Views)
The hint to use an installer helped me figure out what to do.  I was only creating an executable. I did not realize that I could create an installer that included the other parts I needed. Thank you very much Dennis.
Ricardo
(3,726 Views)
