VISA file write works on 32 bit WIN 7 but not 64 bit
Yes... ALL the hardware is the same, I just have one USB cable that I plug into which ever computer is running the test.
The only variable is which computer is running the executable
Message 21 of 33
(3,419 Views)
Not sure why you are setting VISA buffer sizes, but according to the Help,
Set size slightly higher than the amount of data you expect to transmit or receive
Message 22 of 33
(3,416 Views)
The buffer size is specific to the instrument under test and how it does the file storage
Message 23 of 33
(3,411 Views)
Yes, but this setting is for VISA on the PC.
Message 24 of 33
(3,409 Views)
It works fine on one PC but not the other. I'm wondering if it is a driver issue now
Message 25 of 33
(3,407 Views)
A driver issue?
You claimed that the hardware is identical except for the UBS-serial cable.
Message 26 of 33
(3,405 Views)
The hardware on the tester, the USB hub, the calibrated barometer, the CP2103 USB to RS232 converter, the IORelay card, and the unit under test are all identical. The difference is the computer running the executable. They are 2 different PC's.
Message 27 of 33
(3,403 Views)
The Status of the I/O Trace will tell you if any errors or warnings occurred during communication. Looking briefly at the file you attached, I see some timeout errors.
If the comptuers can be connected to the same network, you may also want to consider remote debugging of the executable to gain some insight on where the code is failing on the 64-bit computer. You can use the debugging tools on the development machine to monitor the executable on the target machine:
Remotely Debugging Executables in LabVIEW
Taylor B.
Message 28 of 33
(3,400 Views)
That looks like the tool I need!
I will report back ASAP
Message 29 of 33
(3,394 Views)
The remote operation seems to cause quite a delay in the communications. Enough so that the instrument under test times out
Message 30 of 33
(3,384 Views)
