VISA open seems to prevent other visa operations.
This Image gives a better description of the problem. Opening of a new device should not affect currently running and properly operating devices. But they seem to be delayed for timeout duration.
Message 11 of 15
(1,024 Views)
What do you mean by SR?
Message 12 of 15
(1,023 Views)
What do you mean by SR? (Shift register I suppose-if so done). I get the error I expected on the output (Device 1 VISA Open).
VISA: (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system.
Message 13 of 15
(1,008 Views)
Hi Taylorh140,
This is a known issue reported in CAR 366314. For TCP/IP instruments, the VISA Open timeout is technically not configurable, and this affects the execution of VISA Read & Write. The end result is that, when performing VISA Open on a TCP/IP instrument that can't be accessed, other VISA functions cannot execute until VISA Open finishes timing out after two seconds.
The available workaround is programmatically to check that the TCP/IP resource to open is correctly configured and available on the network, and then to only execute VISA Open in this case.
Adolfo F.
Message 14 of 15
(963 Views)
2 Things:
1. I think that CAR is partially fixed/changed. The VISA timeout does seem to respond properly when using VISA Open.
2. The work around is not really a complete work around, If i have a network latency of 200ms even if the resource is available it will still halt communication on other devices for those 200ms.
For now I think the work around will be for me to use the TCP pallete instead of the VISA pallete, I was hoping this wouldn't be the case. I think that I would have to do this for the workaround anyhow. Thanks for your help Adolfo.
Message 15 of 15
(962 Views)
