VISA open
I am trying to read from Labview instead of Hyperterminal using VISA read. But the Visa open gives the error code -1073807202, which is undefined code. While using Hyperterminal i have to reset to see all the contents.What is the problem?Please anyone help.I am new to Labview.
(3,839 Views)
This error is not undefined :
LabVIEW:  (Hex 0xBFFF009E) VISA or a code library required by VISA could not be located or loaded.  This is usually due to a required driver not being installed on the system.
VISA:  (Hex 0xBFFF009E) A code library required by VISA could not be located or loaded.
The results of the search for this error code may help you.
(3,830 Views)
