VISA port cannot be opened after disconnecting a device and reconnecting it
I have this very annoying problem in LabView (2014): I have devices that I'm communicating with over a virtual COM port (VISA). If I erroneously disconnect or power off that device while my VI is running, then I get an error, which is normal - but if I repower or reconnect the device, the VI will never run again and gives the following error:
Error -1073807343 occurred at VISA write in xy.vi
Possible reasons: (Hex0xBFFF0011) insufficient location information or device or resource is not present in the system.
When this happens, I can still see the COM port in the COM port list (placing a control on the front panel); But it's marked as connected. It appears to me that if I unplug the cable, VISA doesn't properly close/release the port and it remains there as some kind of zombie port, and when I reconnect my device, it still can't access it because the old error is still there.
The only thing that helps is to restart LabView, which is a bit of a nuisance.
Can anyone suggest how to solve this without restarting LabView?
(3,315 Views)
Close the VISA session when you get the error.
(3,293 Views)
Alternatively you can unconditionally close the reference before you try to open it, and ignore/clear the warning produced from an uninitialised reference.
GCentral
(3,276 Views)
