VISA read serial --- bluescreen after 5-20min
Hi
I have following problem:
I send with the arduino via “Serial.println” a increasing long number 32Bit. If I read it with the Serial Monitor form the Arduino SDK is everything working perfect.
If I read it with LabVIEW I have a blue screen after 5-20 min. At the moment I haven’t no idea where the problem to search.
PS: I can't using the LIFA because i need the Arduino as a SPI Slave interface.
Windows Error description:
Problemsignatur:
  Problemereignisname:                       BlueScreen
  Betriebsystemversion:                        6.1.7601.2.1.0.256.48
  Gebietsschema-ID:                             2055
Zusatzinformationen zum Problem:
  BCCode:                                               d1
  BCP1:                                                    00000000000000B8
  BCP2:                                                    0000000000000002
  BCP3:                                                    0000000000000000
  BCP4:                                                    FFFFF880087E2161
  OS Version:                                          6_1_7601
  Service Pack:                                       1_0
  Product:                                               256_1
Dateien, die bei der Beschreibung des Problems hilfreich sind:
  C:\Windows\Minidump\070413-11029-01.dmp
C:\Users\Manuel\AppData\Local\Temp\WER-508485-0.sysdata.xml
LabVIEW program:
Have you any Idea where the Problem can be?
Thanks alot.
Manuel Keel
Message 1 of 12
(7,760 Views)
Don't you want to read the property "Bytes at Port" instead of "Data Bits". (You have "data bits" configured as 8 on the left, so this seems a very uninteresting property to read. ;))
Message 2 of 12
(7,730 Views)
Hi, I had the same problem, and I solved It reinstalling the last version of NI-Visa and installing the packet "Labview Interface for arduino" with "VI Package manager"
Good luck!
Message 3 of 12
(7,598 Views)
Any luck on finding a solution for this?
Message 4 of 12
(6,697 Views)
Like Christian Altenbach I say that you need anothe function namely bytes at port.
Now you are probably asking too much bytes and I already have a corrective action request (CAR number I have to lookup) for such a blue screen with Arduino serial communication.
I found a workaround by not asking more bytes than are available where I originally relied on a defined endcharacter. I proofed that this crashes windows on several machines and operating systems so I blamed NI but got not the feedback until now that it is reproduced or solved.
I have another Arduino project in which a customer reported a crash last Monday so I really would like to work together to find a solution.
greetings from the Netherlands
Message 5 of 12
(6,687 Views)
Thanks alot Albert!
I will inform about the results soon, as i have 3 pc's running which fail daily. 🙂
Message 6 of 12
(6,686 Views)
Cool! The blue screen disapeared. 🙂 Thanks for helping.
Message 7 of 12
(6,521 Views)
I'm glad you got it to work for you. I'm still confused as to why everyone is using bytes at port when:
println()
Description
Prints data to the serial port as human-readable ASCII text followed by a carriage return character (ASCII 13, or '\r') and a newline character (ASCII 10, or '\n'). This command takes the same forms as Serial.print().
It seems to me that we'd want to use the newline character. Am I missing something?
Reference: http://arduino.cc/en/Serial/Println
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 8 of 12
(6,515 Views)
The reason I use bytes at port is that when I was using the endcharacter, I got also the blue screen. And my customer did not like that at all.
So I reported it and the car still stands in the visa group.
In fact I don't like that NI iseems a black hole, corrective action request goes in, followed by silence........
It is almost a year now!
Message 9 of 12
(6,505 Views)
Dang, I should have read your post with an eye toward more detail. Sorry about that Mr. Geven. I might have to take a look at the sketches/vi's used for LIFA and LINX and see what method they are using.
Arduino aside I wonder if this is affecting other apps using the serial port...Instrument Drivers etc.
This could get really ugly.
Didn't mean to hijack this thread.
Message 10 of 12
(6,496 Views)
