VISA serial port & front panel issues
Hi ! My VI communicates with my instrument using the serial port. I configure the port using 'VISA Configure Serial Port', creating a front panel control for the input 'VISA resource name'.
When I create an executable with the Application Builder, and install the exe on another pc, I can no longer communicate with the instrument and the VISA Resource control is greyed out, i.e. I cannot select between COM1 and COM2 etc. However, the control and the VI work fine as an exe when run on the original pc.
On the PCs where I want to run the exe, I can communicate fine with the instrument using Hyper Terminal. Original PC = win2000, labview 6.1, other PCs where exe installed = win98 & win95.
Any suggestions ?
(3,326 Views)
HI,
It looks like you don't have the NI-VISA driver installed on the target machine. Drivers are not automatically included with the LabVIEW executable installer.
NI provides a run-time version of the NI-VISA driver free of charge. Download it at:
"http://digital.ni.com/softlib.nsf/webcategories/9AD71162B755F0E786256BBC005F001A?OpenDocument&node=...
DiegoF
(3,326 Views)
