VISA serial port reading/ writing
hi, i'm writing program for microcontroller that using serial port for reading and writing data.
after boot, program must to wait 10 seconds to receive data from serial port
code: init serial port by VISA
//init of ssp protocol
        viSetAttribute (ssp, VI_ATTR_TERMCHAR_EN, VI_FALSE);   //disable termination char
	viSetAttribute (ssp, VI_ATTR_ASRL_END_IN, VI_ASRL_END_LAST_BIT);
	viSetAttribute (ssp, VI_ATTR_ASRL_BAUD, 38400);
	viSetAttribute (ssp, VI_ATTR_ASRL_PARITY, VI_ASRL_PAR_NONE);
	viSetAttribute (ssp, VI_ATTR_TMO_VALUE, 15000); //TMO 15 seconds
	viFlush (ssp, VI_ASRL_IN_BUF_DISCARD);
	Sleep(1);
reading from the port
if (!strcmp(command,"readBuffer")) //Reading TST
incount = 0;
otcount = 0;
viGetAttribute(ssp, VI_ATTR_ASRL_AVAIL_NUM, &num_bytes);
while(num_bytes <= 3)
viRead (ssp, Databuf, num_bytes, &RTCount);
Databuf[RTCount] = '\0';
viFlush (ssp, VI_WRITE_BUF);
viFlush (ssp, VI_READ_BUF);
packetdata = strtok(Databuf,";");
if(!strcmp(Databuf, ";TST;") || !strcmp(Databuf, ";TST") || !strcmp(Databuf, "TST;") || !strcmp(Databuf, "TST"))
InsertTextBoxLine (panelHandle, PANEL_DEBUGWINDOW , ++debugBoxLine, Databuf);
//*************** Auto Scroll ***********************
SetCtrlAttribute (panelHandle, PANEL_DEBUGWINDOW, ATTR_FIRST_VISIBLE_LINE, debugBoxLine);
flagout = 1; nboards++;
return 1;
 are this code optimal , can i change and remove while loop from the code?
and another issue when i'm writing to the port
code:
if(!strcmp(command,";ANALOG;"))
	     Sleep(1);
	    incount = 0;
            otcount = 0;
	    num_bytes =0;
	    strcpy(command, ";IN?;");
	    viWrite(ssp, command, 10, &RTCount); //10 bytes
	    while(num_bytes < 11)
			if(num_bytes < 5)
 when program sending command ;IN?; it's gets some data. but sometimes buffer is empty. and i added while loop for checking num_bytes for received data.
may be i can remove this while loops and use some VISA attributes? for waiting received data?
thanks
(5,521 Views)
Hi Arbo,
I’m not aware of any specific attribute to handle that particular functionality. Typically you would poll for the data as you are doing, or perhaps have some event driven technique. However, I find the NI-VISA Programmer Reference Manual a great resource for looking through specific functions and attributes. Also check out the Community Examples and the examples that are included with the driver.
Perhaps someone else on here might have some more insight into optimization techniques that they have found successful.
Here are some additional resources that you may find useful:
NI-VISA User Manual
David C
(5,478 Views)
David
thanks very much, i will check the examples and manual
(5,460 Views)
viQuery(ssp, ";IN?;", "%s", Databuf);
 hi i found this command for sending formatted data to serial port and receiving formatted data to Databuf variable.
but now i get an error Timeout expired before operation completed.
and when i making debuging by F8 button i see the right data received in Databuf
using this command attribute:
viSetAttribute (ssp, VI_ATTR_TMO_VALUE, 1000);
 not helping me.
(5,436 Views)
Have you tested communication with a program such as hyperyterminal, putty, MAX? You aren't sending s termination character and most serial instruments require that. In my experience, a timeout is usually caused by an incorrect cable, wrong com settings, or bad data in the write.
(5,432 Views)
when i using viWrite and viRead functions
everything is fine and working good.
the reason that i searching for another  commands is issue that viRead sometimes not receiving the answer from microcontroller and i dont want to use loops such was in the start of this post
(5,424 Views)
