VISA version independence in vb.net 2010
Hello I have a vb.net 2010 application that references the NI VISA dll. This application only works on other computers if they are running the same version of NI  VISA.
How do I compile the vb.net application to make it work with any version of NI VISA installed on a client computer?
Markus
(4,338 Views)
Hello Markus,
In this case, your best bet would be to include with your executable a config file (appname.exe would have appname.exe.config) that includes binding redirect information for VISA versions.
Where it refers to the VISA assembly in your config file you would include a line as follows:
<bindingRedirect
oldVersion="old assembly version"
newVersion="new assembly version"/>
The following documentation discusses this:
http://msdn.microsoft.com/en-us/library/7wd6ex19(v=vs.110).aspx#bkmk_redirectingassemblyversionsatth...
Ian M.
(4,321 Views)
Can you send me this example?
z-jzhao@163.com
(2,065 Views)
