11-06-2017 02:49 PM - edited 11-06-2017 03:03 PM
In order to get the firmware on the Velleman k8090, I send
\04\71\FF\00\00\8C\0F
However, as soon as I write the above command in a string constant (codes display), it becomes \04q\FF\00\00\8C\0F
The 71 has changed to q. Any ideas why this is happening? The command still works.
Solved! Go to Solution.
11-06-2017 03:21 PM
the letter q is 71 hex
