ViPrintf Timeout
I have been writing a GPIB Labwindows Program using ViPrintf statements and also tried ViWrite statements in place of ViPrintf.
With the instrument I am communicating with I get Timeout Popups stating that the Operation did not complete before the Timeout
occurred.
Any Ideas?
  Thank You,
  Gary
(4,874 Views)
I rewrote the program so that I used ibwrt and ibrd  I get errors with this other program such as ENOL Timeout.  When I have timeout set
for 10 seconds it still times out.  It is not because of VISA library  It is looking like the problem is the Physical connection or the device I am trying to talk to.
(4,859 Views)
The box I was sending messages to required that I read the messages right after writing one message.  And I disabled Serial Polling.  Addiitionally
after reading the responses immediately and displaying the responses I found out which messages were not accepted by the box.
Messages accepted without errors do not timeout.
(4,846 Views)
Hey Gary,
Thanks for posting all the steps you went through thus far Smiley Happy ! After reading the messages after writing, are your timeout errors eliminated?
Justin E
National Instruments R&D
(4,840 Views)
Hi Justin,
Yes, I was getting timeouts after sending a message that was faulty.  By reading all responses immediately after sending a message I could identify the bad message.
After a bad message was sent the Instrument, the Instrument will expect a *CLS to clear the instrument.  If I just send messages back to back without reading the responses and I send a bad message the next message I send after the bad message will timeout because the instrument will no longer respond.  The instrument is waiting
to be cleared.
Thank You,
Gary
Message Edited by golson on 07-10-2009 06:36 AM
(4,829 Views)
