Visa Interactive Control
How to chage the Comport setting for ASRL::INSTR in the Visa Interactive Control Software.
(3,460 Views)
You don't. The control is specifying a reference. You'd then use the properties and methods of that class to set things like baud rate, etc. Your other posts indicate you are using LabWindows. Installation of NI-VISA should have installed examples. Did you take a look at them?
(3,452 Views)
