Visa Read
I just did some major cleaning up of your code.  The major changes were to make an event for handling each of your commands.  A Timeout event was added to do the reading of oscilloscope data, an Array Value Change event was added for sending the switch data, and a Stop Button Value Change event was added for stopping the main loop.
Message 11 of 14
(2,608 Views)
Now the explaination.
when run nothing would happen until an event fired.  then the case structure took over but no events will be processed until the while loop completed.  which won't happen until you change the tab.  the code isn't "Bad" but very strangely constructed.
Message 12 of 14
(2,593 Views)
Thanks for Help...Still i want to know what was problem in my previous code??
Message 13 of 14
(2,570 Views)
Bad architecture.  Likely race conditions due to the use of local variables.  Sending data through the serial port even though nothing changed (this is most likely your culprit).
Message 14 of 14
(2,563 Views)
