Visa Resource Unavailable, Device in use my another program
Does the device show up as a parallel port after installing the VISA driver?  Didn't think so.
Revert to the devices supplied driver and try again from there.
Shane.
Message 11 of 14
(1,610 Views)
Hi i have the same problem like this guy. I accidently installed a VISA driver for a device while i don't need the VISA . How do i revert to the old driver?
kind regards .
Message 12 of 14
(1,541 Views)
Accepted by topic author DatTechBoy
Hi Dennis_Dutoit,
If you want to revert to the original driver you'll need to uninstall the VISA driver you installed, then re-install the original driver. You should be able to uninstall the VISA driver from Control Panel, under National Instruments Software.
I hope this helps! Thanks,
Emily C
Message 13 of 14
(1,519 Views)
Thank you .
Message 14 of 14
(1,506 Views)
