Visa TCP/IP Instrument not detected with external lan adapter in MAX
When I setup a new VISA TCP/IP resource in MAX using my internal LAN adapter I can validate and communicate with the instrument.
But, when I try and use an external USB to LAN adapter I can't validate or communicate with the device. Is it possible to switch the communication from
my internal adapter to the USB one?
(3,610 Views)
Which IP-adresses and netmasks do you use for your internal adapter, the external adapter and your instrument ? Are you able to ping your instrument ?
(3,600 Views)
Internal Adapter (PING OK):
DHCP Enabled Yes
Autoconfiguration Enabled Yes
IP Address 192.254.234.244
Subnet Mask 255.255.0.0
Default Gateway 192.254.234.244
External USB Adapter (PING OK):
DHCP Enabled Yes
IP Address 169.254.120.172
Default Gateway 169.254.120.172
Instrument Adapter:
DHCP Enabled Yes
IP Address 169.254.89.140
Default Gateway 169.254.89.140
(3,576 Views)
