Visa write and read from two com ports simultanously
How can I read and write up to 8 (PCI485) com ports at the same time. When I use while loops for every com ports. How can I determine that every while loop whith its own com port runs independantly ?
(3,566 Views)
You can do VISA communication with multiple com ports at once. You should make sure that your serial vi's are re-entrant. There is a Knowledge Base that discusses the use of multiple serial ports at once (link below). You should also make sure that there is no data dependence from one loop to the next. Since LabVIEW is data dependent, once it has all necessary data, the loop will run. To determine if your loops are running independently, you can turn on "Highlight Execution" mode and see what order things occur in.
http://ae.natinst.com/operations/ae/public.nsf/fca7838c4500dc10862567a100753500/59458684cf7861cc862565410061db3b?OpenDocument
If you are not using LabVIEW, make sure that your application is multi-threaded.
Kim L.
National Instrumen
ts
(3,566 Views)
An updated link to the KnowledgeBase mentioned in the answer is:
http://digital.ni.com/public.nsf/websearch/59458684CF7861CC862565410061DB3B?OpenDocument
Molly K.
Molly K.
Web Support & Operations Manager
(3,566 Views)
