Visual Basic 2005 codes for using ActiveX supplied by Jobin Yvon Spectrometer (iHR320)
I am writing VB2005 codes using calling the ActiveX (COM) components for the spectrometer iHR320.
Usually calling com object resulted in some control in remotely connected iHR320 successfully.
But in my case, some ActiveX call results in OnReceive-like events that must be
caught in a sub-procedure written in main body of form (not in COM object source).
JY provided example source codes in VB6. Therefore, as long as using
the VB6 compiler, the iHR320 can be controlled successfully.
Previously when I used VB6, writing some subprocedure like
Private Sub Objects_Initialize(ByVal e As Long......)
can catch this event fired by ActiveX.
Objects.GetSlitWidth()
End Sub
But, it's not possible to catch in VB2005. I tried to add "handles ....." after
the finishing paraenthis of the subproc arguments, but it was in vain.
Private Sub  Objects_Initialize(ByVal e As Long......) handles Objects.Initialize
How should I do to work around. I tried to have questions to Jobin Yvon,
but there is no response.
I heard that it corresponds to "OnReceive" eventhanlder in the language of c++.
Please share your successful experience about the migration from VBb related to
the connection with ActiveX (COM) objects. I am expecting responses
from those who is familiar with VB2005 as weol as C++.
LabView is too expensive for me. It is not option for me.
Thanks in advance fro your kind response.
(4,217 Views)
Why are you using Visual Basic .NET 2005?
The free express version is available for 2015.
Can you provide the ActiveX controls that you are using?
(4,202 Views)
Thanks for the reply. I use VB2005 because I write it on WinXP OS so that
I can compare the compilation results between VB6 and VB2005.
Needless to say, the XP machine cannot be connected to the internet.
Jobin Yvon provided software development kits consisting of COM objects.
Some of those COM objects raise an event.
I need to write eventhandler statements in a modules,
corresponding to this event rise.
JY provided example codes written in VB6 language. In these,
there is surely declaration of the withevent variable like,
Public WithEvents mono1 As New ........
in the VB module.
In the case of dot-net language, should I write statements like below?
Sub Mono1_Initialize(ByVal ... As Long, .......) Handles Mono1.Update
When I wrote the above statement, VB2005 IDE generated an error message.
I have no idea why this is generated.
In my guess, there is some statement in the COM object,
RaiseEvent Mono1_Initialize(Byval.... as ., ByVal.. as ...)
(4,183 Views)
It worked finally by adding "handles monoObj1.Initialize"
to the relevant subproc.
In addition, upgrade service adds some namespace (or class name)
to the declaration of some variables. Therefore, one should
carefully return the variables to the original forms.
Thanks everyone who responded to my post.
(4,156 Views)
