Visual Studio 2008 compliler error
In my old application written with VC++ MFC I was using Measurement Studio 6.0 to control GPIB devices. Now I tried recompiling this project with Microsoft Visual Studio 2008 and got the same error in two places:
Error: “error C4430: missing type specifier - int assumed. Note: C++ does not support default-int”
Source code: nidataproxy.h(line 181) :inline operator ! () const;
Source code: nidataproxy.inl(361) :
CNiSafeArrayProxy::operator ! () const {                        return (rawData == NULL);Simple fix by adding one specifier do inline definition does not solve problem, because this definition is used with different types. Do you have solution for this problem?
(3,599 Views)
Can you successfully build any of the GPIB examples in C:\Documents and Settings\All Users\Documents\National Instruments\NI-488.2\Examples\DotNET3.5  and did you re-install the 488.2 driver after installing Measurement Studio 2008?
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(3,580 Views)
