W2K crashes with PCI-GPIB
I am using a PCI-GPIB card under W2K, with driver version 1.60. All diagnostics
indicate that the card is functioning correctly, and there are no hardware
conflicts. I am able to use WaveStar to communicate with the Tektronix 694C
scope. When using Excel/VBA macros to control an oscope, W2K crashes to
a blue screen, with the message:
Hardware Failure
Please Contact Hardware Vendor
A hard reset is required to re-start the system. There is no error logged
by W2K, and using NI Spy reveals no consistent macro command that is causing
the failure. I have followed all the suggestions in the Troubleshooter,
Knowledge Base, etc. I have tried a different PCI-GPIB card from an known-good
system. I have tried this card in a
different, identical system. Any other
suggestions would be greatly appreciated.
Cory Allen
(4,429 Views)
What type of computer are you running? Please indicate the make and model.
Eric Singer
"Cory Allen" wrote in message
news:3a10657f@newsgroups.ni.com...
diagnostics
694C
> Hardware Failure
causing
> the failure. I ha
known-good
> system. I have tried this card in a different, identical system. Any
other
> Thanks,
> Cory Allen
(4,429 Views)
I am using a Pentium III 733/Intel VC820 motherboard/256M RAM/Matrox Millenium
G400 that was built by our IT dept. In addition to the GPIB card, there
is an Intel PRO/100+ network card, an In-Target Probe (ITP) card, and a SoundBlaster
Live (which has since been removed, reducing the frequency of the crashes,
but not eliminating them.). I have tried a variety of PCI slot configurations.
Cory
"Eric Singer" wrote:
>What type of computer are you running? Please indicate the make and model.>>Thanks,>Eric
Singer>"Cory Allen" wrote in message>news:3a10657f@newsgroups.ni.com...>>>>
I am using a PCI-GPIB card under W2K, with driver version 1.60. All>diagnostics>>
y, and there are no hardware>>
conflicts. I am able to use WaveStar to communicate with the Tektronix>694C>>
scope. When using Excel/VBA macros to control an oscope, W2K crashes to>>
a blue screen, with the message:>>>> Hardware Failure>>>> Please
Contact Hardware Vendor>>>> A hard reset is required to re-start the system.
There is no error logged>> by W2K, and using NI Spy reveals no consistent
macro command that is>causing>> the failure. I have followed all the suggestions
in the Troubleshooter,>> Knowledge Base, etc. I have tried a different PCI-GPIB
card from an>known-good>> system. I have tried this card in a different,
identical system. Any>other>> suggestions would be greatly appreciated.>>>>
Thanks,>> Cory Allen>>>>
(4,429 Views)
Did you uninstall ACPI-PC mode and set you PC to Standard-PC, so that it
uses no dynamic IRQ assigns this causes much trouble ? Could be a way !
(Possible in the drivers section)
"Cory Allen" schrieb im Newsbeitrag
diagnostics
694C
> Hardware Failure
> by W2K
causing
known-good
other
> Thanks,
> Cory Allen
(4,429 Views)
Check out this knowledge base on ni.com: 23R7A8LS. It talks about the way
Win2k controls power affecting the performance of the GPIB card.
"Cory Allen" wrote:
>>I am using a PCI-GPIB card under W2K, with driver version 1.60. All diagnostics>indicate
that the card is functioning correctly, and there are no hardware>conflicts.
I am able to use WaveStar to communicate with the Tektronix 694C>scope.
When using Excel/VBA macros to control an oscope, W2K crashes to>a blue
screen, with the message:>> Hardware Failure>> Please Contact Hardware
Vendor>>A hard reset is required to re-start the system. There is no error
logged>by W2K, and using NI Spy reveals no consistent macro command that
is causing>the failure. I have followed all the suggestion
s in the Troubleshooter,>Knowledge
Base, etc. I have tried a different PCI-GPIB card from an known-good>system.
I have tried this card in a different, identical system. Any other>suggestions
would be greatly appreciated.>>Thanks, >Cory Allen>
(4,428 Views)
