We have been using serial devices for more than ten years (proprietary acquisition cards and third party devices) using a variety of languages (BASIC, CVI, LabView...). I always found that the main problem are correct configuration of the serial port and cabling: once these items are correct, it's easy to obtain some reply from your devices (maybe not so easy to obtain the CORRECT reply or to interpret it...).
I've used both old style VIs (vith LV 5) and VISA with success on the same devices: still I am a little confused about VISA. Maybe would be better some explanatory document by NI about VISA and serial communication.
Anyway, my approach is at present: don't bother about control panel and/or MAX configuration of the port: open the device and configure i
t as you need at the beginning of your application.
Next use simple VISA Write and VISA Read VIs.
Be sure to set the correct timeout: some devices are extremely long in replying (for example: an Infratek wattmeter takes as long as 45 seconds to send measures if you ask to it an harmonic analysis...!).
