What does RegisterGpibGlobalsForThread() mean?
A Visual Basic example program calls function RegisterGpibGlobalsForThread() which is exported from Gpib-32.dll. But this function is not documented in NI-488.2 Function Reference Manual for Windows (321038g). Chapter 3 of that manual describes four important functions but does not mention this one and the related Unregister function. What does this kind of registration mean? (I might code in either VC++6 or VB6.)
(7,164 Views)
RegisterGpibGlobalsForThread() is a function used exclusively for the VB language interface. This function allows somebody programming in VB to access the NI-488.2 global variables: ibsta, iberr, ibcnt. This function was added as a workaround to allow VB users to access these variables, much as they would access them if using C or C++. You shouldn't need to worry about it, as this functionality is encapsulated in the vbib-32.bas.
(7,164 Views)
Thank you very much. If your answer were included in the manual then I wouldn't have had to ask 🙂
There is a related question which I would like to ask for clarification on though. If I end up doing multithreading programming in VB, then the four functions which are documented in the manual for thread data can be called directly from a VB program? Even in VB, I will not have to call RegisterGpibGlobalsForThread() in that case?
(7,164 Views)
Does this mean that when  you are developing applications using C# , there is no need to use this call?
Human knowledge belongs to the world
(6,667 Views)
Hi trashvin,
Yes that is right, you will not need to use this call if you are developing applications using C#. The NI-488.2 drivers do ship with example code that you may refer to as a starting point when developing your code. These can be found in this location on your hard drive:
C:\Documents and Settings\All Users\Documents\National Instruments\NI-488.2\Languages\DotNET2.0
Good luck!
Rasheel
(6,633 Views)
I'm using the C to communicate with a GPIB device and using the GPIB 488.2 Library. but I don't see
the RegisterGpibGlobalsForThread() function. any tips? I'm converting a code from VB to CVI and I came accross this line while Initializing the device.
Do I need to register the globals?
Thank you
(6,548 Views)
Hi Tiger81,
No, the RegisterGpibGlobalsForThread( ) function was strictly used as a workaround for Visual Basic. It is NOT needed for any other programming language such as C.
Hope this information helps.
gpibtester
(6,505 Views)
