Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
What is the limit of SPY?
GPIBRFAnalyzers
Since1990
Member
11-19-2002
06:43 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Spy slows down significantly after loading the 26060th line of a file.
The Windows 2000 paging file is set to 1024MB
I attempted to attach the file, but the Servlet page times out.
0
Kudos
Message
1
of 2
(3,090 Views)
Reply
Re: What is the limit of SPY?
AaronK
Active Participant
11-20-2002
10:36 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Is there a reason you are trying to capture so much data with NI-SPY? Typically SPY is used ony for debugging, but when the count gets that large, the debugging use is moot.
Best Regards,
Aaron K.
Application Engineer
Kudos
Message
2
of 2
(3,090 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
