What's the difference between Viread in VC and VB?
In VB,the  "VISA32.DLL" Declare is
Declare Function viRead Lib "VISA32.DLL" Alias "#256" (ByVal vi As Integer, ByVal Buffer As String, ByVal count As Integer, ByRef retCount As Integer) As Integer
and use like
viread(vi ,String,count ,retCount
In VC,
#include <visa.h>
and use like
  viRead(vi, (UCHAR *)buf(), bufSize, &actual);
Buffer in VB is a String,but in VC is a  Integer array.
Why?
(2,911 Views)
It may be related to language differences and how data transfer is optimized in the respective languages. For instance, if the buffer can be sent as either a string or integer array but VB handles strings better, strings will be used. Is there a specific reason that this information is required for your application?
Kevin T.
Applications Engineering
(2,868 Views)
thank you
 I use
 status = viRead(vi, strRes, 4096, retCount)
 the result only 18 bytes, do you know why?
(2,862 Views)
If you haven't yet, I would take a look at the examples for VISA reads for VC and VB. There are also examples that install when you install drivers on your computer.
Example VISA Message-Based Application
NI-DAQmx, NI-VISA, and NI-488.2 Visual C++ Example Locations
Kevin T.
(2,856 Views)
