What should I use to connect to various devices?
A system is already in place and I would like to implement LabVIEW to monitor readings from various pressure controllers, power sources, flow controllers, etc... Each has its own computer interface ports and I was wondering what would be the best way to connect all these to labVIEW. I may also wish to automate the system in the future by turning the various devices on and off. Is there any hardware necessary for all these connections? I am just getting started using LabVIEW and any help is greatly appreciated.
(3,114 Views)
There may be hardware necessary but since you don't specify the type of computer interface ports the instruments have, all I can do is give you some general comments. A common instrument bus is called GPIB. The instruments connect using special cables to a GPIB controller in the PC. Some instruments have a serial port connection (RS-232). Each instrument would need a dedicated serial port on the PC and connected with a fairly inexpensive cable. Expansion is possible with dedicated RS-232 cards or with USB to RS-232 converters. Some instruments have a USB connection. You would need a cable to connect those to the PC and maybe a USB expansion device depending on the number of instruments. Lastly, some instruments have an ethernet connection. The only ha
rdware required would be a PC with a NIC card and possibly a network hub or switch. LabVIEW is capable of communicating over all of these types of connections.
(3,114 Views)
