When I try an install the GPIB drivers from the CD for NT I get an error. It says the GPIB software is not properly instal
led. Please run the GPIB setup software from your disk. Once it is installed use ibconf to modify your settings. Under error information is says file: reginfo.c Line: 3601 and Item knownDLLs. Am I missing a file, what is reginfo.c, what is error 3601?
(3,167 Views)
led. Please run the GPIB setup software from your disk. Once it is installed use ibconf to modify your settings. Under error information is says file: reginfo.c Line: 3601 and Item knownDLLs. Am I missing a file, what is reginfo.c, what is error 3601?I might recommend either copying the contents onto your harddrive and install from the fixed disk or download the NT driver from http://www.ni.com/support/gpib/versions.htm
(3,167 Views)
