When i control 2 instruments separately it works, when i combine them in one program one works the other not?????
Dear friends,
I am controlling TDK Lambda via RS232 using VISA, and power sink via USB using the labview driver of the company (Genyses). In doing that separately they work just perfect, but when i do them in the same program the VISA one keeps showing error in reading step. Can you please share if you know what can the problem be?
(3,762 Views)
it would help if you shared YOUR program.
(3,750 Views)
1. Set Read the numver of bytes specified from 5 to at least 7  because dot and \r also symbols. I would recommend set 64.
(3,730 Views)
this is what i thought first time, i increased the number, however still showing some error! . Thanks for replying.
(3,724 Views)
