Where can I find driver packages for various PXI cards?
I am working with a PXI chassis loaded with various hardware, including DIO, DSO, DMM, RF Mux, relays, and matrix switch.  Each time I start to try to develop VIs for one of these cards, I find it is missing software.  For example, I downloaded NI-DAQ to be able to use the DIO card and am now downloading NI-SWITCH to be able to use the matrix cards.
Can these software packages be found on the NI Developer Suite DVD?  Should they have been pre-installed when the PXI chassis shipped?  Each of these packages so far has been > 1GB and download times are extremely long.
Thanks for your help,
Zack
(2,857 Views)
You can order configured systems and yes, the drivers are on the DVDs. Did you not look for them?
(2,856 Views)
